dehmer
Mar 06, 2012Aspirant
NV+ X-RAID Expansion with WDC drives
I'm quite happy with my NV+ X-RAID running for 2+ years with 4 x WDC WD10EADS-00M2B0 (1 TB). One drive has quite a high Raw Read Error Rate (5941912). So I guess it might be failing soon. Don't know,...
de_niro
Mar 06, 2012Guide
You mentioned that your device was worked on 4.1.6 firmware which is only support 512-byte hard drive,so,you'd better to upgrade firmware to 4.1.8 first, then backup all data and factory default your device to support 4K sector drive.
- Sep 06, 2016Retired_Member
