dehmer
Mar 06, 2012Aspirant
NV+ X-RAID Expansion with WDC drives
I'm quite happy with my NV+ X-RAID running for 2+ years with 4 x WDC WD10EADS-00M2B0 (1 TB). One drive has quite a high Raw Read Error Rate (5941912). So I guess it might be failing soon. Don't know,...
dehmer
Mar 07, 2012Aspirant
UPDATE:
I upgraded FW 4.1.6 -> 4.1.8 and one of the fresh drives (WDC WD20EARX-00PASB0) is initializing/synching right now (probably to a sector size which is less than adequate)
Sector sizes which are not correctly aligned cause (major?) performance issues, right?
Doing a factory default/reset will definitively erase all data (format disks with new sector size)? If a backup is just considered a safety net for a failing factory default, I would skip this step because the data is not that important. Knowing it will be gone in any case is a different matter...
- Sep 06, 2016Retired_Member
