dehmer
Mar 06, 2012Aspirant
NV+ X-RAID Expansion with WDC drives
I'm quite happy with my NV+ X-RAID running for 2+ years with 4 x WDC WD10EADS-00M2B0 (1 TB). One drive has quite a high Raw Read Error Rate (5941912). So I guess it might be failing soon. Don't know,...
mdgm-ntgr
Mar 07, 2012NETGEAR Employee Retired
dehmer wrote:
Sector sizes which are not correctly aligned cause (major?) performance issues, right?
Yes. Write performance tends to become terrible (e.g. < 1MB/s)
dehmer wrote:
Doing a factory default/reset will definitively erase all data (format disks with new sector size)?
Yes all data will be wiped.
The start sectors for each disk in partition.log (in logs zip file downloadable via Status > Logs > Download all logs) will be divisible by 8 indicating 4k sector partition alignment.
