dehmer
Mar 06, 2012Aspirant
NV+ X-RAID Expansion with WDC drives
I'm quite happy with my NV+ X-RAID running for 2+ years with 4 x WDC WD10EADS-00M2B0 (1 TB). One drive has quite a high Raw Read Error Rate (5941912). So I guess it might be failing soon. Don't know,...
mdgm-ntgr
Mar 07, 2012NETGEAR Employee Retired
Replace the disks before factory reset. You can power off the NAS, replace the disks and use the boot menu: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
- Sep 06, 2016Retired_Member
