r00x
Feb 03, 2014Aspirant
NVX expanding array - not getting expected capacity?
Hi everyone, I've got an NVX which was bumping up against the available free space so I decided to expand the array. The original drives were a mish-mash (having already been expanded): 1: 2TB ...
Feb 03, 2014Guru - Experienced User
"Vertical" expansion (using the extra capacity when you upgrade to a larger disk) usually takes a reboot.
Your disk configuration should give you about ~3TB (which is 2.7 TiB). Note Frontview reports TiB and GiB (multiples of 1024, not 1000). 1 TB of space on drive 3 cannot be used with your current mix of disks.
