daztrue
Oct 12, 2020Aspirant
NVX firmware displaying constant error messages
Accessing the firmware (RAIDiator 4.2.30) of my ReadyNAS NVX 4210 displays no Model, Serial etc on the home page, and despite the normal pop-up window informing of additional logs, clicking to view l...
- Oct 15, 2020
I'd try these steps (in order)
- updating to 4.2.31 (if you have enough functionality to do that)
- disabling Kaspersky
- either updating your browser (your version is over 2 years old) or trying chrome
I'm not seeing your issue with current Chrome or Firefox.
Oct 12, 2020Guru - Experienced User
What browser are you using?
Do you have any internet security software installed on the PC?
If you can get to the firmware update page, you might want to manually install 4.2.31 and see if that helps.
- daztrueOct 15, 2020Aspirant
Firefox ESR 52.8.0 (32-bit)
Kaspersky Internet Security 18.0.0.405
Is it advisable to attempt an update with error messages - or is there no better time?! It's just that I've had this version for so long without issue. And I don't want to risk irreparable damage.
- StephenBOct 15, 2020Guru - Experienced User
It looks as though the browser may be the issue. I'm on the verge of upgrading but my OS is too old to upgrade my browser, however I have Brave on my mobile so accessed the NAS that way and found no error messages, the logs displayed (though greyed out), and Vault is still shown as unticked, and unlike on desktop, doesn't display other fields.
With this additional info, I'd be prepared to wait until I've upgraded, now that it seems to be the browser. Do you think that would be okay or better to still proceed with the firmware upgrade now?
Also, would you say it was fine to upgrade from within a virtual machine?
