Bains
Dec 07, 2014Guide
Older DUO (sparc) Questions
We have a number of older Ready NAS Duo systems. These devices were put into service in 2008 and have been working well. Disk replacement for failing drives works and they keep chugging along. Fi...
Dec 08, 2014Guru - Experienced User
You need to allow less secure apps even if you don't use two-factor authentication. However, even if that setting is wrong, you will still reach the smtp server.
mdgm wrote: Does your gmail account have two-factor authentication? If so, you will need to create an application specific password and allow less secure apps.
Normal settings for google mail are
smtp.googlemail.com
smtp port 465
use TLS checked.
If all outbound internet connections seem to be failing, then you should also check the settings on your IP address. A wrong gateway, subnet mask, or DNS server can all create that symptom.
