Bains
Dec 07, 2014Guide
Older DUO (sparc) Questions
We have a number of older Ready NAS Duo systems. These devices were put into service in 2008 and have been working well. Disk replacement for failing drives works and they keep chugging along. Fi...
Dec 08, 2014Guru - Experienced User
You can.
Bains wrote: Is there a way to save the configuration and then reset system to a 'fresh' image with the latest firmware. I can loose the data but would rather not have to reconfigure from scratch.
You save the configuration via system->config backup in frontview. Check everything accept data volume (e.g. don't choose the "everything" button either). Make a note of any add-ons you have installed for later.
Then
(a) do a factory default. You can do this via system->update in frontview. Upgrade firmware as desired.
(b) reinstall any add-ons you had installed before (do this BEFORE restoring the configuration)
(c) then restore the config backup you saved earlier.
(d) reload your data.
