tony359
Sep 14, 2021Apprentice
On Network bonding/teaming
Hi there, As others in the past, I'd like to use both my Ethernet ports on my Pro6 to see if I can speed up things. My PC has two network ports (1x1Gbit and 1x2.5Gbit). I am aware Windows 10 does...
Sep 14, 2021Guru - Experienced User
Your bonding mode is set up between the PC (or NAS) and the switch - so which modes work depend on what you switch supports.
The manual is a bit unclear, but the GS108E doesn't seem to support either static LAGs or LACP. That suggests the only options on the NAS would be TLB or ALB, and the only option on Windows is "switch independent".
As you are finding, the gains are generally pretty small. You might also find that you end up with worse performance on devices that are accessing the NAS over wifi or a single ethernet connection.
While you would have more options if you upgrade the switch, I wouldn't do that just to get bonding. In general, bonding has the most gain if you have a lot of devices accessing the NAS at the same time.
tony359
Thanks Stephen - as usual.
In fact it turned out that the small gain in writing was the 2.5Gbit Ethernet port - which turned out to be somehow faster in 1Gbit/s mode. I've tested now in Windows 10 on single link and the numbers are the same. So it was not wasted time in the end, I've gained approx. 20MB/s in writing by just using the 2.5Gbit port! :)
I hear what you say - and you've mentioned so many times on this forum! I was just hoping to be able to gain something as the MB came with two ports, I did not selected it because of that feature so I was hoping to get a free speed upgrade!
As you say, better switches - particularly those which support speeds >1Gbit/s - are expensive so probably not worth the money.
If I ever decided to get more speed I guess I should look into swapping the whole chain - Ethernet ports, switch, NAS. Expensive but probably the only way to get some actual benefit - what is your thougt on that?
Thanks
