joakimu
Oct 27, 2016Follower
OpenVPN download speed extremely slow on Readynas duo 104
Hello,
I've recently set up a OpenVPN tunnel from my ReadyNas Duo 104 with my VPN service provider (ivpn.net). Everything is working fine, but I am experiencing massive performance losses.
I'm on a 100/10 Mbit connection and without VPN i can max out my bandwidth's download speed on my NAS. As soon as i connect to the VPN my download speed goes down to as low as 8Mbit/s. I have no problems what so ever using the vpn on other platforms (windows, ios), and the server responds within 20-30ms.
I've been messing around with the MTU size, different ports and everything I could find out.
Does anyone know what I can do? Is the hardware in the NAS simply too weak for encrypting my data to meet those speeds?
Any tips are helpful.
Thanks!
- sotrackLuminary
And this link can help you
https://www.ivpn.net/knowledgebase/66/My-VPN-is-slow-what-can-I-do-to-make-it-faster.html
I would replace openVPN to IPSec with ivpn.net
- sotrackLuminary
OpenVPN performance is dependent of encrypting key size. This parameter is used for openvpn sertificate key generation (encrypting key). Below is oficial comment from openvpn.net for key generation script:
Increase this to 2048 if you are paranoid.
This will slow down TLS negotiation performance
as well as the one-time DH parms generation process.****************************************/
set KEY_SIZE=1024I think you need contact to ivpn.net and request regenerate sertificate with less "paranoid" security key if it possible.
