Vaclav
Nov 13, 2013Aspirant
OS 6.1.4 apache2 mod_rewrite .htaccess problem
Hi,
I'm trying configure apache2 to enable mod_rewrite in my HTTP enabled share folder. I use that folder as my personal webserver for PHP development.
I have root access via SSH to my ReadyNAS, I know little bit of linux commands, but this I first time configure Apache, so I lack knowledge of conventions there. I followed tons of forum threads and tutorial, some of them points me to right direction, but majority of them was obsolete or too brief for me to understand.
I figured, that mod_rewrite is installed and enabled, but not working in my web share probably because Apache ignore my .htaccess file. Some folks suggests change
I'll sum my problems with this approach in following list.
AllowOverride Noneto
AllowOverride All
- I have mess in config files. Debian uses custom modular Apache2 configuration and ReadyNAS inserts another mess in this order, because some files are reconfigured after restart. Some older tutorials points the configuration files to /etc/frontview, but I suggest, that for OS 6.1.4 the right folder is /etc/apache2 . Right?
- I changed AllowOverride All in
/etc/apache2/sites_enabled/000-fv-http
With that, my document_root containing .htaccess is forbidden, so the .htaccess starts to do something, but not the way i wanted. - Some tutorials suggests add new virtual host as new file into
I tried it several ways, but it always brokes apache2 service, so it fails restart. - I also dont understand paths in virtual hosts files. My HTTP share have name www, so system path to some project is
/data/www/[project]/[document_root]
but I presume, that path for virtual host would be/var/www/www/[project]/[document_root]
Am I right? - There is also noted importance of permissions for apache config files and for .htaccess. People say, that it should have the same user:group as apache. Apache config files has root:root, in apache2.conf the user and group are represented by envar
$[APACHE_RUN_USER]
that envars are not listed when I execute command set. There is user:group www-data:www-data in /etc/passwd, but is that even related with apache somehow?
$[APACHE_RUN_GROUP]
In the end, I'm realy confused from all of that. I'm sure, that I don't do everything completelly wrong, but I don't do something important here, something important there and it just don't work, but it starts doing me mad.
Can you help with advice. Thanks in advance. I'll be also glad for good, understandable, up-to-date, article about apache basics.
- VaclavAspirantOK, so i sorted it a little bit. Back to the points:
- ReadyNAS frontview, that means web administration and addons, are in
/etc/frontview/
Files in this folder are (or was) persistent through restart/upgrade, so it is (or was) used as hack for keep settings.
The main apache configuration files are in/etc/apache2/
and while experimenting with settings, there is no need to go to /etc/frontview. - Still the same result (403 Forbidden) when edit
Changed<Directory />
--Options FollowSymLinks
++Options All
--AllowOverride None
++AllowOverride All
</Directory>
Incriminated .htaccess# Apache configuration file (see httpd.apache.org/docs/current/mod/quickreference.html)
# disable directory listing
Options -Indexes
# enable cool URL
<IfModule mod_rewrite.c>
RewriteEngine On
# RewriteBase /
# prevents files starting with dot to be viewed by browser
RewriteRule /\.|^\. - [F]
# front controller
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule !\.(pdf|js|ico|gif|jpg|png|css|rar|zip|tar\.gz)$ index.php [L]
</IfModule>
# enable gzip compression
<IfModule mod_deflate.c>
AddOutputFilterByType DEFLATE text/html text/plain text/xml text/css application/x-javascript text/javascript application/javascript application/json
</IfModule> - Tutorials related with VirtualHosts are mostly about clean domain names → redirect/translate from www.example.com to www.readynas.com/webshare/... so if I need put mod_rewrite into operation, there is no need fiddle with VirtualHosts, right?
- Paths in configuration files are regular system paths, I got it now :oops:
- Still confused here, dont know if it's even related with my problem.
- super_poussinVirtuosowhy not creating you own conf file for your http site without touching /etc/apache2/sites_enabled/000-fv-http which could be rewritted after a fw upgrade ?
- VaclavAspirant
I created separed apache configuration file for my project/etc/apache2/sites-enabled/010-nette
That file has following contentroot@nas-35-05-E7:/data/www/nette/www# cat /etc/apache2/sites-enabled/010-nette
<Directory /data/www/nette/>
AllowOverride All
Options +Indexes
Order allow,deny
Allow from all
</Directory>
That file put my .htaccess into action, but it leads to 403 / forbidden. Now playing with permission.
Files in web shared folder must be owned by webserver user. Variables$[APACHE_RUN_USER]
are defined in /etc/apache2/envars so
$[APACHE_RUN_GROUP]cat /etc/apache2/envars
tells, that webserver user:group pair on OS6 is admin:admin. Can also be verified by checking running apache2 processps -aux | grep apache2
I decided to change webserver user from admin to www-data, so I changed envars from admin to www-data and restarted apache. Files and folders in web shared folder had mixed ownership and permissions, so to be sure, that ewerything is owned by the same user with propper permission, I ranchown -R www-data
on folder /data/www/nette/, where I need mod_rewrite enable. Still getting 403 / Forbidden
chmod -R 0755 - VaclavAspirantReturning envars back to admin. Chown user back to admin:admin. The problem is probably not related with file permission. By some security reason, the rewrite engine is premitted to work only on enabled virtual hosts.
Changed /etc/apache2/sites-enabled/010-nett toroot@nas-35-05-E7:/# cat /etc/apache2/sites-enabled/010-nette
<VirtualHost *:80>
DocumentRoot /data/www/nette/www/
<Directory /data/www/nette/www>
RewriteEngine On
AllowOverride All
Order allow,deny
Allow from all
</Directory>
</VirtualHost>
Page works, no more forbidde, but RewriteEngine is off, not sure if .htaccess is doing something. - VaclavAspirantFinished my Apache2 excourse. PROBLEM SOLVED,
will sumarize solution and tips for the others.- Firstly, the problem was not related with file permission. Ownership was set propperly to admin:admin, which is what you need for web access as well as for local network sharing. There's no need to fiddle with permissions in most cases.
- You need create your configuration in
You should create separed file for your configuration. Since all files in that folder are included by apache in order by filename, it is good convention to start your configuration file with number higher than alredy existing files. There are configuration files for frontview (ReadyNAS administration page), that begins with 000- and apps configuration files begins with 090-, I named my configuration file like 099-. - You could put your config file directly in sites-enabled folder or you can put it in sites-available, which will make that site available, but not enabled yet. You can than enable that config file with command
a2ensite <your_config_name>
It is usefull, if you want sometimes shutdown that site with commanda2dissite <your_config_name>
but as far as I know, otherwise from this purpose, it doesn't matter. - Because of some security reason, the rewriteEngine is only permitted to operated under configured virtual host. I firstly configured only <Directory>, which led to 403 : forbidden. In the end, I use this config
Apache documentation recommends leave all directory paths without last slash and you can ommit double quotes, but I saw config files with that in place and it seem to operate normally.
<VirtualHost *:80>
ServerName <your_server_name>
DocumentRoot <your_path_to_DocumentRoot>
<Directory <your_path_to_DocumentRoot> >
AllowOverride FileInfo Options
Order allow,deny
allow from all
</Directory>
</VirtualHost> - In <Directory> section, I allowed to override FileInfo and Options, which is perfect minimum for RewriteEngine to work. You must also enable FollowSymLinks in options!
- Than you have to link <your_server_name> to your NAS, that means modify hosts file on your machine. I use Win7, so I modified
Windows/system32/driver/etc/hosts
added new line<your_NAS_IP> <your_server_name>
I use serverName without top level domain (country code), so it'll not conflict with some existing page. - Once its all configured, you can enter <your_server_name> into address bar of your web browser and it should redirect you to your web shared folder with rewriteEngine on. Beware of your browser, sometimes it perform search your_server_name on search engine, instead of access it. It is crucial to acces your folder through <your_server_name>. I accessed them differently before and that also led to error 403 : forbidden.
- Dont forget to run
service apache2 reload
after changes to take effect.
