SecretSquirrel
May 05, 2014Aspirant
OS 6.1.7 no scheduled scrubbing?
Having lost the volume in the past on my Pro Business due to a double failure (second drive failed during a rebuild), I scheduled a weekly RAID scrubbing job to avoid this in the future, and I've been...
max_kublin
Jun 12, 2014Tutor
btrfs is a multi-purpose program - of course you need to know what your are doing.
This will give you all the options of the command:
btrfs --help
e.g. watch the progress (=Status) of a running scrub:
root@MAKUNASWEB:~# btrfs scrub status /data
scrub status for 56a3ce48-a09e-4156-becc-7ee4a89e2b19
scrub started at Thu Jun 12 14:31:54 2014, running for 1002 seconds
total bytes scrubbed: 301.91GiB with 0 errors
scrub started at Thu Jun 12 14:31:54 2014, running for 1032 seconds
total bytes scrubbed: 308.87GiB with 0 errors
scrub started at Thu Jun 12 14:31:54 2014, running for 1227 seconds
total bytes scrubbed: 354.92GiB with 0 errors
root@MAKUNASWEB:~#
btrfs --help
root@MAKUNASWEB:~#
