SecretSquirrel
May 05, 2014Aspirant
OS 6.1.7 no scheduled scrubbing?
Having lost the volume in the past on my Pro Business due to a double failure (second drive failed during a rebuild), I scheduled a weekly RAID scrubbing job to avoid this in the future, and I've been...
max_kublin
Jun 13, 2014Tutor
regardless how you initiate scrubbing and/or defragging, you need to be aware that this takes a long time.
In my case, scrubbing of 4TB of data took 24685 seconds which is close to 7 hrs.
I thought that scrubbing scans the *whole* disk space, but the output indicates that only the
occupied space on the disks was scrubbed?
In turn this could mean that when my disks contain more data, e.g. 20TB, then scrubbing could take 5 x 7 = 35 hrs?
root@MAKUNASWEB:~# btrfs scrub status /data
scrub status for 56a3ce48-a09e-4156-becc-7ee4a89e2b19
scrub started at Thu Jun 12 14:31:54 2014 and finished after 24685 seconds
total bytes scrubbed: 4.05TiB with 0 Errors
btw. scrubbing of approx. 3TB of data on my Readynas Pro6 (6 x 2TB disks, Radiator 4.2.6) takes about 5 hrs,
which is in the same range.
