ScottChapman
Dec 17, 2014Apprentice
OS 6.2.x on Pro2?
Not sure how I didn't notice this before, but should OS6.2.x run well on my Pro2? Any issues I need to be concerned with?
mdgm-ntgr
Dec 17, 2014NETGEAR Employee Retired
Should work great!
You can of course update direct to 6.2.1 beta if you prefer: http://www.readynas.com/forum/viewtopic.php?f=161&t=78265
Do note that the upgrade requires a factory reset so backup your data first.
Also note that this is not supported by NETGEAR so if you run into issues you will need to make use of the forums or some other 3rd party service for help.
