ScottChapman
Dec 17, 2014Apprentice
OS 6.2.x on Pro2?
Not sure how I didn't notice this before, but should OS6.2.x run well on my Pro2? Any issues I need to be concerned with?
ScottChapman
Dec 22, 2014Apprentice
mdgm wrote: Yes. After upgrading to OS6 you would use the same images as you use to upgrade your 316 for future updates.
So, do I install the prep image first and then the regular os6 firmware? Or do I need to install the 6.2.1beta linked in the other thread?
