ScottChapman
Dec 17, 2014Apprentice
OS 6.2.x on Pro2?
Not sure how I didn't notice this before, but should OS6.2.x run well on my Pro2? Any issues I need to be concerned with?
ScottChapman
Dec 26, 2014Apprentice
OK... Got my first problem...
So, none of my shares are available to anyone. Not on any windows client or Mac client.
SMB is on and AFP and the shares are visible. Bit I get an error every time I try to connect.
On the windows machines (which are requiring a username/password just to connect to the server) I get an error about "windows cannot access..."
I do have user accounts set up, for for the shares I also have guest access and anyone can read/write.
Not sure what's going on. I get the same behavior when I create a new share as well... I made sure the protocols (SMB and AFP are running for the share)
Any ideas? Did I need to do a factory reset after getting to the final 6.2.2 firmware?
