ScottChapman
Dec 17, 2014Apprentice
OS 6.2.x on Pro2?
Not sure how I didn't notice this before, but should OS6.2.x run well on my Pro2? Any issues I need to be concerned with?
ScottChapman
Jan 02, 2015Apprentice
OK, thanks. Got it reinstalled. Need to wait for my dad to wake up before I can test it. Did you see anything interesting in the logs at all?
When the system came up, I did happen to see that there was two home directories for my user. I had played around changing the name of the user to see if the problem was some interaction with the name.
So I changed then user name from Rob -> rob. still had the issue so I changed it back rob -> Rob
However, there are now both a Rob and a rob folder in /home. I can't do a rmdir on the empty /home/rob folder:
I don't think this is what my problem was... I was having the issue long before doing the test. But at this point how can I clean it up?
root@Server:/data/home# rmdir rob
rmdir: failed to remove `rob': Operation not permitted
