ScottChapman
Dec 17, 2014Apprentice
OS 6.2.x on Pro2?
Not sure how I didn't notice this before, but should OS6.2.x run well on my Pro2? Any issues I need to be concerned with?
dsm1212
Jan 02, 2015Apprentice
I know this is normally not required to connect, but do you have the workgroup set on the pc's to the same as the NAS? This is under accounts->authentification on os6. Access Type should say "local users" on that same window in os6. Also, disable your virus scanner on the pc's when you are diagnosing any weird connectivity problem.
steve
steve
