fetopher
Jun 28, 2016Aspirant
OS 6.5.1 set bogus creation/modification dates
Just updated to 6.5.1 this morning and suddenly, all files in all directories have been updated with incorrect/bogus creation and modification dates. Using this in a shared/mult-user setting where we...
- Jul 07, 2016
It looks like the culprit was Amazon Cloud Drive sync. I think the reason 6.5.1 exposed the issue was it introduced "support for bi-directional sync with Amazon Cloud Drive accounts" per the release notes email I received from Netgear.
So, if you use Amazon Cloud Drive sync, I suggest not upgrading to 6.5.1 until you have it turned off. Any then maybe after you upgrade, don't turn it back on? I'm not sure. I don't need to use it, so I'm going to leave it off.
fetopher
I just downgraded to 6.5.0 and the setting of incorrect creation/modification dates seems to have stopped, but everything it touched is still wrong. Spot checking directories it looks like almost all files were touched, so this remains a big issue.
Is no one else having this issues with 6.5.1?
- JennCJun 29, 2016NETGEAR Employee Retired
Hello fetopher,
I guess it is best to contact support center to report this, so that you can show to the expert too what happened after FW update on remote session.
