RobNG
May 05, 2017Aspirant
OS 6.6.1 and OS 6.7.1 - Can't create new directory via FTP on external USB device
Hi I've searched the forums but not managed to find anything similar, so here's my problem: A friend who has a USB HDD (formatted NTFS) connected to one of my ReadyNAS units for off-site backu...
- Jun 02, 2017
This will be resolved in 6.8.0.
RobNG
May 23, 2017Aspirant
Well my post above has had nearly 100 views but no replies. :smileysurprised:
Can anybody else reproduce the behaviour described above (unlikely it's confined to just me as it's happening on at least two of my ReadyNAS units)?
Would someone from NetGear care to comment, and if/when you're convinced this problem exists, when can a fix be expected?
- capazMay 23, 2017Tutor
RobNG wrote:Well my post above has had nearly 100 views but no replies. :smileysurprised:
Hmm, guess that rules out the "obvious" bits you originally asked about. ;-)
Are there no clues in the permission settings in Network Access --> FTP --> Security and File Access --> Security for the shares of the different types of filesystems? I understand that it used to work for you; just wondering if the new behavior isn't maybe reflected in changes in default settings for shares using the corresponding filesystems.
<shrug>
- RobNGMay 24, 2017Aspirant
Thanks for your reply.
I've just double-checked and nothing has changed in the permission settings so that's not the cause.
I mentioned in my OP the workaround that we'd been using whereby I would create a new directory for my friend locally via the web GUI, and although I ddn't actually state it, my friend is then able to copy/create new files into that (or any other existing) directory.
Something new to add to the description of the behaviour which I've only just tried is that it is possible to rename an existing directory via FTP.
Edit: I just noticed it's also possible to delete a directory via FTP.
- RobNGJun 02, 2017Aspirant
So 4 weeks have passed since my OP and it's disappointing that NetGear haven't bothered to reply either to say they have investigated the reported behaviour, or to confirm that it exists.
As the workaround described was becoming too tedious to perform, I've had to re-format the USB HDD from NTFS to EXT4 which was something we didn't really want to do, so thanks for your help and concern NetGear. :manfrustrated:
