vuilverwerking1
Jan 09, 2012Aspirant
OS Reinstall added -snap to shares #(17605122) *Solved*
After problems with my ReadyNAS NVX Pioneer i did a OS Re-install. After this all my shares apear twice with de second name ending with -snap. Anybody know what to do?
mdgm-ntgr
Jan 09, 2012NETGEAR Employee Retired
Work with support on this issue.
"-snap" indicates there is an active snapshot.
Snapshot is not a feature of the Pioneer.
Unless you have the Online Filesystem Check option under Volumes > Volume Maintenance (not sure if this tab is on Pioneer) and it's running you shouldn't have "-snap" shares.
- Jul 15, 2018Retired_Member
