Lidy
Nov 15, 2023Follower
OS Reinstall issues
hello. I tried to reinstall the OS because I lost the password for the RN314 model, but I noticed that it was stuck for a long time, so I wrote this post to ask for help. 1. Confirm lost passwor...
Nov 15, 2023Guru - Experienced User
Lidy wrote:
4. Only ‘Booting... Checking root FS’ on the front LED and ‘File System Checking...’ on the RAIDar remain on for more than 2 hours.
Sounds like a disk problem.
Try powering down the NAS and then test the disks in a Windows PC with vendor tools (Seatools for Seagate, Dashboard for Western Digital). Label the disks as you remove them. You can connect the disks to the PC using either SATA or a USB/SATA adapter or dock.
Do you have a backup of the data?
- Jul 15, 2018Retired_Member
