dbanfs
Nov 29, 2018Tutor
OS Reinstall Stuck at Checking Root FS
ReadyNAS Pro running OS6 in X-RAID mode with a RAID 6 volume, recently reported a disk failure. Upon replacing the disk, the unit failed to start resync/recovery so I tried rebooting the unit. When...
Sandshark
Dec 01, 2018Sensei
You don't give a lot of details. Was the drive blank when inserted? Was it hot inserted or inserted before power on?
Assuming a cold insert of a non-blank drive, you need to go back to the original 5 good drives and boot with those, then hot insert the new one. Connecting to a PC and removing all partitions on the new one before hand may also help.
- Jul 15, 2018Retired_Member
