loha
Jun 14, 2017Aspirant
OS reinstall via USB
My ReadyNAS 314 was updated with latest OS 6.7.4 the 4th June 2017. Some day after is was closed down according to calenda action. After that it was sleeping some days and Iturned it on yeaterday wit...
- Jun 15, 2017
The process for desktop units with an old BIOS and a backup button (e.g. your RN314) is very simple:
1. Press and hold backup button
2. Press power button to turn the NAS on
3. Continue holding the backup button till it boots off USB.If you are unable to recover the system using USB Boot Recovery you could open a case for a hardware issue and support could try to assist and if that fails they'll verify that you are the original purchaser from an authorised reseller and if that checks out proceed to do a RMA.
There are suggestions on the community about using Rufus to create the USB Boot Recovery key and alternative files that can be used to boot to a tech support mode like state (can help if your USB key has no partitions on it).
Personally on units such as yours that have a HDMI port I find hooking up to a HDMI display helpful. You'll see the difference between a normal boot and booting off USB.
Sandshark
Jun 15, 2017Sensei
In my experience, older is better here. I found a 2GB Lexar I had in a drawer works great.
mdgm-ntgr
Jun 15, 2017NETGEAR Employee Retired
- lohaJun 15, 2017Aspirant
I have tried this a couple of times.
My understanding is that the NAS cannot find the USB during the boot.
The stop on the monitor looks the same all the time.
The secuesn of pusing the bottoms, are the time sensitive, if that could be the case.
Any special requirements on the USB stic, more that whats stated in the instruction already.
- lohaJun 17, 2017Aspirant
It is now solved.
I used the steps given by mdgm, and I used an "old" USB.
The NAS did not indicate it was booting from the USB. The procedure ended and everything was "turned off". What is the next step when everything looks like to die.
What I did was to start up the NAS in the normal way and everything worked in its normal way.
This was the first time I used this community.
Without all the ideas I have got was very helpful.
Thanks!
- Jul 15, 2018Retired_Member
