mfb9
Oct 20, 2022Aspirant
OS6 NAS and Riello iDialog 400 UPS
Hello. I have a couple of NAS's, running OS6, and have had a disk failure from a power cut, so I have bought a UPS. i thought that as the current drain is small compared to a server etc, and all i ...
Oct 20, 2022Guru - Experienced User
mfb9 wrote:
I had hoped that NUT was what I was looking for, and that this would be in the downloadable apps, but I can't find it.
NUT is built into the NAS software, so there is no app to install. It will automatically recognize a lot of UPS when the USB cable is connected.
If you didn't connect the USB cable yet, then start there. If you did connect it, then try a different USB port on the NAS and see if that works.
- mfb9Oct 20, 2022Aspirant
Thanks Stephen,
That's really good of you to reply so quickly. I had already connected it; I've now tried all three USB ports and nothing looks any different. How do I know if it's recognised it? Do I get a different menu in the UPS settings page? Or should it show in logs (it doesn't) or somewhere else?
On a different subject (forgive me) I accidentally wriggled the PSU plug wen i was changing the USB lead over, and it momentarily disconnected, and I realise that I'm probably more likely to have a problem with loss of DC than loss of mains! All the PSUs I have that seem to fit are wobbly, so I assume the plug size is incorrect - is there a definitive spec for the plug for a 12v coaxial ReadyNAS PSU (not the 4-pin ones, they're much more reliable!)? I'll post this separately of course if that's preferable.
Thanks again,
Mark
- StephenBOct 20, 2022Guru - Experienced User
You should see the UPS show up on the UPS settings page. This is what I see (this NAS happens to have an APC UPS).
Not sure. Maybe the mods can help??? ( Marc_V or JeraldM ). Or perhaps Sandshark
Just want to add that I am seeing 5.5mm x 2.1mm on some third-party adapters.
