DownloaderUK
Nov 08, 2020Aspirant
OS6 NOW WORKS ON X86 LEGACY
Hello all. I am looking to upgrade to OS6 and although l have found various links here, l am looking for a clear start to finish guide please with all links to the correct files & fw. I am comp...
DownloaderUK
StephenB,
Thank you for the reply. Do you have a guide on how to upgrade the RAM to 2GB by chance?
Thank you
Thank you
Nov 09, 2020Guru - Experienced User
No, but it's not difficult. You need to remove the skin on the left side of the chassis (facing the front of the unit), and you'll see the RAM slots. In my case, only one of the two slots was used.
You want pc6400 ddr2 800mhz 240 pin DIMM (non-ECC, unbuffered). https://www.crucial.com/memory/ddr2/ct25664aa800 is one option that should work.
- SandsharkNov 09, 2020Sensei
Since the unit doesn't use dual-channel RAM, you can upgrade the empty slot to more if you like with no speed penalty for the banks being mismatched. Up to 2GB sticks are available cheap. 4GB 2Rx8 ("low density", as opposed to 2Rx4 "high density") are needed and are not as common and the board can't support more than 8GB total.
- DownloaderUKDec 02, 2020Aspirant
I downloaded ssh and did an ls command. Here is the output. Can you advise what you see here? I am concerned as l have allot of folders that appear to have these ?? folders but l cannot cd into them. Any advice?
- StephenBDec 02, 2020Guru - Experienced User
I'm not sure where you are here.
- Have you converted to OS-6?
- Did you log into the NAS using root as the username (using the admin password)?
Your directory list doesn't look right. This is what I see on my Pro-6 (recently converted to OS-6)
root@PRO://# cd // root@PRO://# ls -al total 64 drwxr-xr-x 1 root root 168 Nov 28 06:48 . drwxr-xr-x 1 root root 168 Nov 28 06:48 .. -rw-r--r-- 1 root root 0 Nov 28 06:48 1 drwxrwxr-x 1 root root 168 Nov 25 12:04 apps drwxr-xr-x 1 root root 1330 Nov 24 16:13 bin drwxr-xr-x 1 root root 0 May 21 2012 boot drwxr-xr-x 1 root root 178 Nov 25 12:01 data drwxr-xr-x 17 root root 3560 Nov 24 16:14 dev drwxr-xr-x 1 root root 2516 Nov 26 16:01 etc drwxr-xr-x 1 root root 54 Nov 24 16:12 frontview drwxr-xr-x 1 admin admin 10 Nov 24 16:13 home drwxr-xr-x 1 root root 462 Nov 24 16:12 lib drwxr-xr-x 1 root root 40 Nov 24 16:12 lib64 drwxr-xr-x 1 root root 0 Jun 4 2012 media drwxr-xr-x 1 root root 0 Jan 25 2016 mnt drwxr-xr-x 1 root root 72 Nov 24 16:13 opt dr-xr-xr-x 196 root root 0 Nov 24 16:11 proc drwx------ 1 root root 64 Nov 24 16:36 root drwxrwxr-x 23 root admin 820 Nov 28 06:48 run drwxr-xr-x 1 root root 2590 Nov 24 16:13 sbin drwxr-xr-x 1 root root 0 Jun 4 2012 srv dr-xr-xr-x 12 root root 0 Nov 24 16:13 sys drwxrwxrwt 1 root root 94 Dec 2 10:17 tmp drwxr-xr-x 1 root root 70 Nov 24 16:12 usr drwxr-xr-x 1 root root 146 Nov 24 16:13 var root@PRO://#
- Sep 05, 2015Retired_Member
