DownloaderUK
Nov 08, 2020Aspirant
OS6 NOW WORKS ON X86 LEGACY
Hello all. I am looking to upgrade to OS6 and although l have found various links here, l am looking for a clear start to finish guide please with all links to the correct files & fw. I am comp...
AdrianoBolzani
Jul 03, 2022Aspirant
It worked flawlessly. Thank you.
The restoring has been painful. 5Tb will take over 7 days with a lot of Re DOs because some erros on file's names or something similar.
Safari and Chrome still show unsecured access. Any suggestion to fix it?
Regards
Jul 03, 2022Guru - Experienced User
That's because the NAS is using a self-signed certificate. The simplest thing to do is just click though it. The connection is still encrypted (despite the warning).
- Sep 05, 2015Retired_Member
