Anonymous
Sep 05, 2015OS6 upgrade question on legacy Pro 6
Hi All, I have been reading the forum and came across the upgrade thread (OS6 now works on x86 Legacy). I have a couple quick questions so here they are. Is it stable at this point without re...
- Sep 06, 2015
1- Backup all your data since the upgrade will factory reset everything and wipe the data
2- download "PREP4TOR6_0.1-x86.bin"
3- install it like an add-on, then DON'T REBOOT yet.
4- download R4toR6_latest.bin
5-install it like a normal firmware upgrade.
At the t reboot, it will install OS6 6.3.5, it will take some times (10-15mins) so no worries. You can check when your readynas is ready with raidator, as usual.
dsm1212
Sep 06, 2015Apprentice
Works great on my pro 6. Highly recommend the switch. You need to reload your data as it's not an upgrade per se, but a fresh install.
steve
mdgm-ntgr
Sep 06, 2015NETGEAR Employee Retired
There is an add-on you can install before installing the firmware update. The add-on allows you to avoid the need to do a manual factory default as it triggers one at the appropriate time.
- RootaxSep 06, 2015Luminary
You can go directly to 6.3.5 btw, it works great on our legacy products.
For me, the major gain was smb writing speed. OS6 brings SMB3, my writing speed was about 85-90mb/s under OS4, now I saturate my 1gb link and write at 110-115mb/sec on my Pro 4. It's not a game changer, but it's a free :D
- AnonymousSep 06, 2015
What is the file/add-on that does the automatic update? Do I put the lates OS6 bin file over that or does it go right to 6.3.5.
Thanks
- mdgm-ntgrSep 07, 2015NETGEAR Employee Retired
You could reboot at Step 3 if you wanted to but it would be a waste of time. The factory reset would not be triggered till after you instal the upgrade image to 6.3.5.
