JDi
May 24, 2019Aspirant
pdf files issues in Ready NAS
Current firmware 6.10.0 Very simple set up, NAS and 2 computers with full access. I've been using the same unit, same computers and same software, I created a pdf file from QuickBooks using C...
May 25, 2019Guru - Experienced User
Have you only seen this the one time?
Did you look in the log zip file for errors?
- JDiMay 27, 2019Aspirant
it happened already 3 or 4 times, with different files on different folders...I did check the log files but no errors found.
- StephenBMay 28, 2019Guru - Experienced User
Did you look in the log file zip, or just browse with the admin web ui? There's a lot more info in the log zip.
Do you have strict sync turned on in the share? If not, try turning it on and see if the behavior changes.
- JDiJun 02, 2019Aspirant
I did check detailed logs, but no errors found, I strongly believe it was an update on my NAS, I didn't have this problem before and nothing has changed, except the firmware on my NAS, can I remove the last (or last 2) firmware without losing data?? Any Netgear tech that can offer some info here?? All help is much appreciated.
