JDi
May 24, 2019Aspirant
pdf files issues in Ready NAS
Current firmware 6.10.0 Very simple set up, NAS and 2 computers with full access. I've been using the same unit, same computers and same software, I created a pdf file from QuickBooks using C...
JDi
May 27, 2019Aspirant
it happened already 3 or 4 times, with different files on different folders...I did check the log files but no errors found.
May 28, 2019Guru - Experienced User
Did you look in the log file zip, or just browse with the admin web ui? There's a lot more info in the log zip.
Do you have strict sync turned on in the share? If not, try turning it on and see if the behavior changes.
- JDiJun 02, 2019Aspirant
I did check detailed logs, but no errors found, I strongly believe it was an update on my NAS, I didn't have this problem before and nothing has changed, except the firmware on my NAS, can I remove the last (or last 2) firmware without losing data?? Any Netgear tech that can offer some info here?? All help is much appreciated.
- NycomJun 19, 2019Aspirant
I am also having this issue.
User saves PDF to the NAS.
They open fine, and then when they go back to them later they show 0KB.
Did anyone get a fix for this?
- JDiJun 19, 2019Aspirant
Hey! it looks like nobody in the community cares about this issue or nobody know...let's compare my situation with yours...are you by any chance syncing the NAS with Dropbox or G drive??
I am using the NAS 212
Firmware 6.10.0
under cloud services I am backing up using Dropbox with Sync Direction: Upload local storage changes only
and also backing up with Gdrive with Bidirectional Sync
No Apps installed and no automatic backup has been set up
