Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
Justin_S
Sep 19, 2011Aspirant
adam.p wrote: I have got the same problem.
4.1.7 Read 30-35 MB/s Write 14-16 MB/s
4.1.8 Read 10-13 MB/s Write 12-14 MB/s
back to 4.1.7 Read 30-35 MB/s
I tested it two times.
Thanks Adam. It's good to hear I'm not alone and I'm glad you found a solution, temporary as it is. You'll probably agree, rolling back the firmware isn't an ideal solution ... sooner or later you always have to upgrade.
In my case, it's *really* soon ... 4.1.7 isn't compatible with Lion :(
Justin
