Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
Justin_S
Sep 19, 2011Aspirant
WSJ wrote: I'm also using a Duo with 4.1.8 - but I've not experienced any performance decrease.
But I've configured the usage of Jumbo frames - maybe that makes the difference?
I'm using a D-Link Gigabit switch (DGS-1005D).
That sounds promising as it suggests this mightn't be a universal problem ... that it might affect certain configurations only. With a mixed network ... some devices compatible with Jumbo Frame and others not ... I suspect I'll suffer performance problems elsewhere if I enable it. In the interests of troubleshooting, though, I'll certainly check it.
For the record, Jumbo Frames were not enable pre-upgrade so this wouldn't explain the performance drop.
Thanks,
Justin
