Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
Justin_S
Sep 23, 2011Aspirant
chaner wrote: I just saw this post. Rolled back to 4.1.7, file copy now runs at 12MBs + and Blu-rays are now streaming without any problems again.
I've had jumbo frames enable all the time so I'm not sure the problem is there.
Thanks Chaner ... it looks like we can discount Jumbo Frames yes, they don't seem to be a common factor. Rolling-back firmware to 4.1.7 seems like a fairly reliable temporary fix which could help many in the short term. Did you need to perform a second factory reset on downgrading?
So far, we all seem to have two disks. Pulling one of mine (dropping down to 1 disk) doesn't magically restore performance, though ...
CIFS (1 disk)
Read: ~16 MB/s (*lower* than my previous 19 MB/s)
Write: ~10 Mb/s (as previously)
Still investigating ...
Justin
