Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
Justin_S
Sep 25, 2011Aspirant
knorrhane wrote: I'm going to try reverting back to 4.1.7 and see if that makes any difference.
On factor is that chaner didn't update to the 4.1.8 beta whilst both me and Justin S did, so it seems the performance decrease has something to do with the beta.
Could be, Knorrhane. Will be really interesting to see if it improves your performance more than mine. The upgrade/downgrade process is thankfully fairly straightforward.
Justin
