Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
Justin_S
Oct 08, 2011Aspirant
Quick update guys ...
I've just checked performance running 4.1.8 Beta and this behaves exactly like 4.1.7 ... good news ...
- Under 4.1.8-T9 with AFP and Bonjour disabled, I measure read speeds of 19.9 MB/s
- Under 4.1.8-T9 with AFP and Bonjour enabled, I measure read speeds of 19.9 MB/s
Write speeds are identical to 4.1.7 too at around 13MB/s. No performance drop like that seen with 4.1.8 Release.
Looks like I'll be running with the beta software for a while but that's far from ideal ... a temporary solution at best. With this (limited) testing it seems like performance problems were introduced between the 4.1.8 Beta and its release, affecting devices with AFP/Bonjour enabled.
As before, I'd be grateful if anyone could confirm this themselves (or contrast it with different behaviour) independently.
Thanks,
Justin
PS. Thanks Dfiler .... your own switch back to 4.1.8-T9 gave me good confidence this would be OK
Justin S wrote: Here how the (good) 4.1.7 firmware performs (*1) ...
- Under 4.1.7 with AFP and Bonjour disabled, I measure read speeds of 19.9 MB/s
- Under 4.1.7 with AFP and Bonjour enabled, I measure identical read speeds of 19.9 MB/s
That's our baseline. Here's how our (broken) 4.1.8 firmware compares ...
- Under 4.1.8 with AFP and Bonjour disabled, I measure read speeds of 18.45 MB/s. A small drop but ...
- Under 4.1.8 with AFP and Bonjour enabled, read speeds are reduced to just 8.2 MB/s. A massive drop. (*2).
Justin S wrote:
Next, I'll be checking the old 4.1.8 Beta to see if it suffers similarly as ... if it's OK, I'll be switching over.
Thanks,
Justin
