Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
Muttzcuttz
Oct 09, 2011Aspirant
Oh dear :(
"Upgraded" to 4.1.8 about 2 days ago, what a mistake. Transfer speeds for files to and from the device plummeted from 20/25MBps to 8/11 MBps over a 1Gbps connection :shock:
Nothing else at all has changed. I use a Windows 7 x64 desktop and both devices are configured for 1000MB Auto Negotiation. Usual tests including running with just a crossover cable between the devices did not resolve.
I tested by grabbing a 4GB file and trying to copy it to the device, and from the device (it reckoned about 7 hours to copy it)
Re-applied RAIDiator 4.1.7 and I'm back with my 20/25MBps speeds :roll:
Think I'll stay away from this upgrade until it's fixed!!
