Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
ard1
Oct 11, 2011Aspirant
milamber3 wrote: At first I thought it was an auto-negotiation problem but now it seems more like something's broke in the Raidiator driver.
Auto negotiation problems may be caused by switches used. That would explain the discrepancy between
32.4/17.1; 22/10.9 ( jumbo on/off; read/write) bonjour on, NV 4x2TB and
15.6/21.7; 1.5/9.5 ( jumbo on/off; read/write) bonjour on, NV+ 4x1TB and
It would mean that the D-Link DGS1005DE on the NV can cope better with Jumbo frames than the 3Com gigabit router (will look up the type and edit).
It can indeed not explain the differences between the
32.4/21.8 Jumbo on read Bonjour on/off and
17.1/21.8 Jumbo off read Bonjour on/off nor the similar number ratio on write using the NV.
