Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
ard1
Oct 12, 2011Aspirant
netnewt wrote: However this did enable to find one problem - my Netgear GS605v2 Gigabit switch - which was limiting throughput for ALL connected devices to the speed of the lowest connected which was my 10/100 PC.
Hi netnewt, thanks for the crosslink and the observation of the lesser speed across all devices on the GS605v2. On the NV+ set up we made sure all devices on the Gb switch are 1000Mb/s and all 100 Mb devices were moved to another switch that has a Gb uplink. We check the LED status occasionally to ensure no 100Mb device sneaks in, so your notice on downgrading to the lesser speed can't be an explanation for the low transfer rates. I think with 60 MB/s (not Mb/s) between macs, I don't need a RAM disk to prove the problem is on the NAS end.
