Justin_S
Sep 17, 2011Aspirant
Performance halved at a stroke (ReadyNAS Duo, 4.1.8) ...
In a busy few weeks, my little ReadyNAS Duo's performance seems to have halved at a stroke. The problem seems to be a consequence of upgrading to RAIDiator 4.1.8 (release) and performing a full facto...
Justin_S
Nov 24, 2011Aspirant
yoh-dah, Fri Oct 14, 2011 wrote: Thanks for the detailed feedback. I'll have someone take a look.
Chewbacca, Fri Oct 21, 2011 wrote: I was able to reproduce the issue. Will have our engineers take a look into the issue.
Hi Yoh-Dah and Chewbacca,
Thanks again for confirming this issue.
Can you offer an update on progress, any insight into the cause you might have (if it relates to configuration, some or all of us may be able work around it temporarily) or an ETA for the next beta firmware which will address the problem?
It's been over a month since we heard from you :(
Thanks,
Justin
