Simie
Aug 12, 2017Aspirant
Periodic "Error communicating with UPS 'UPS' ()." Error
After installing a UPS I get frequent email notifications with "Error communicating with UPS 'UPS' ().", with a paired "Communication with UPS 'UPS' () is OK." arriving shortly after. When I left on ...
- Aug 25, 2017
We're hopful that this issue is fixed in 6.8.1 Beta 1, which is posted in the Beta section of the community. Please report whether this works for you if you have a chance to try it.
Simie
Aug 13, 2017Aspirant
That explains why I didn't see it in the updater, thanks.
Initial results from upgrading the firmware last night appear positive - I haven't had the UPS message yet, whereas before it was a daily occurance. Thanks for the help guys.
Simie
Aug 14, 2017Aspirant
Ahh, I spoke too soon. The error occured again overnight.
My UPS model: APC Back-UPS XS 700U
What should I do from here?
- StephenBAug 14, 2017Guru - Experienced User
Give Netgear folks a chance to respond. In the meantime, I suggest looking at the pattern:
- see if the frequency drops with 6.8.0
- see if these alerts are triggered at particular times or events (for instance disk spinup).
If you keep a USB disk connected, you could also try removing it for a while, and see if the pattern changes.
