ddx
Jul 03, 2017Aspirant
Permission Issues: ReadyNAS RR4312X goes total read only mode, inoperable
We have two of these RR4312X (ReadyNAS 4312 with 10GBASE/T not showing up in the model list above). One is working fine still, the other one went totally read only all of a sudden. Please help! ...
ddx
Jul 04, 2017Aspirant
Hi evan2, thanks for your reply.
I have sent the log file with your handle in the subject.
Thanks
evan2
Jul 04, 2017NETGEAR Expert
Check system logs, filesystem bterfs has errors, then forced readonly,
Jul 03 12:16:11 NSCOL kernel: BTRFS error (device md127): parent transid verify failed on 17416348631040 wanted 95453 found 294341
Jul 03 12:16:11 NSCOL kernel: BTRFS warning (device md127): Skipping commit of aborted transaction.
Jul 03 12:16:11 NSCOL kernel: BTRFS: error (device md127) in cleanup_transaction:1855: errno=-5 IO failure
See mount info, it is ro,
/dev/md127 on /run/nfs4/home type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=257,subvol=/home)
Could do you please create a support case through MyNETGEAR?
https://kb.netgear.com/26905/Creating-a-Support-Case-through-MyNETGEAR
