gillmacca
Mar 10, 2014Aspirant
Permission on files in subfolders
Hi, hope someone can help...I am a newbie when it comes to servers. I have a ReadyNAS NV+ v2, running latest firmware. I am using transmission to download torrents and have set up a folder called d...
gillmacca
Mar 11, 2014Aspirant
Yes, mediabrowser is getting access denied, until I select reset permissions under files and folders, then it accesses the files fine.
Is the owner of the share login the same as the login I use to login to the dashboard?
Mediabrowser is directly access the files.
Don't know anything about windows permissions?
I have several shares that mediabrowser has access to, and the rest are fine. The only difference I can see is that in the download folder, subfolders are sometimes created by the torrents
