diwakar
Sep 17, 2016Aspirant
Permissions don't work anymore RN10x 6.5.1
I recently upgraded to 6.5.1. Around the same time, I also moved over to the new readycloud single signon account. I seem to have done something to the permissions or the access: I (main user) can't ...
- Sep 20, 2016
OK, success! I finally got this to work on all my machines. Here is what I did after searching for similar issues on the forum (in the ReadyNAS for Business section)
In cmd window:
confirm NAS is visible via ping on both \\nasname and \\nasipaddress
type "net use * /delete" will remove any existing connections - wasn't an issue in my case
type "net use t: \\nasname\data /user:admin password" this maps the NAS to t: drive KEEP TRACK OF THE DIRECTION OF THE SLASHES
Invoke windows credential manager (via search in Settings)
create new generic Windows Credential:
\\nasname\data
login: admin
password:
In Windows Explorer:
Delete the old quick access link to "nasname" on the left bar
type in \\nasname in the address ribbon - Works!
Create new Quick Access link
Thanks for all your suggestions. Most of the ideas here are in other ReadyNAS threads, if you start looking for the correct error messages (0x80004000 and 0x80070035).
I don't use a very long email address (12 characters long, @ gmail dot com)
mdgm-ntgr
Sep 20, 2016NETGEAR Employee Retired
Please update to ReadyNAS OS 6.5.2 which is now available!
Are your email addresses longer than 32 characters?
diwakar
Sep 20, 2016Aspirant
In cmd window:
\\nasname\data
login: admin
password:
- JennCSep 21, 2016NETGEAR Employee Retired
Hello diwakar,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
