HughFrederick
Oct 08, 2019Aspirant
permissions nightmare
Ive been struggling to gain access to files that when clicked apon using the Apple finder they open in iturnes. When trying to access SHARE thru BluOS app. they are not indexable or playable?
- Oct 10, 2019
Indeed file folder structure was critical:
drivename/music/artist/tracks ......
drivename/music/ another folder / tracks ....
another folder removed ...indexing of 20,000 music files suceeded :-)
Oct 08, 2019Guru - Experienced User
Do you have read/write access to the folder when you just open it up via finder (not using BluOS)?
HughFrederick
Oct 09, 2019Aspirant
yes;
I can use finder to navigate to any music file and cause Itunes to load and play
- HughFrederickOct 09, 2019Aspirant
heres the nas privlidges
- StephenBOct 09, 2019Guru - Experienced User
Are you using this method? https://support.bluos.net/hc/en-us/articles/360000197008-File-Sharing-MacOS
Once completed, in The BluOS App, select Network Shares from the Settings, Music Library Menu to add shares.- HughFrederickOct 10, 2019Aspirant
