CBCC
Apr 05, 2014Aspirant
Permissions over Network
Hello, I am having trouble with my ReadyNAS Duo V2. I can do anything I want to from the WinXP computer that originally put the files on it, but not with other computers on my network. The ReadyN...
Apr 06, 2014Guru - Experienced User
I agree the NAS is relatively easy to rebuild. Though I think resetting the ownership will work.
CBCC, your volume is getting full. You should consider getting larger disks for the duo. (Your model needs 2 TB or smaller). After you get through this issue, perhaps post back on that.
