CBCC
Apr 05, 2014Aspirant
Permissions over Network
Hello, I am having trouble with my ReadyNAS Duo V2. I can do anything I want to from the WinXP computer that originally put the files on it, but not with other computers on my network. The ReadyN...
CBCC
Apr 12, 2014Aspirant
StephenB wrote: With all due respect to tony359, I don't recommend doing a factory reset (at least not yet). Since you have no "security" tab then you are in user security mode.
First update the firmware.
Then reset the owners and permissions of all the existing shares. The way you do this is through frontview.
(1) select "shares" from the left menu, then "share listing"
(2) for each share, select the CIFS icon (should be the first after the share name)
(a) scroll down to "advanced CIFS permission"
(b) check "Automatically set permissions on new files and folders"
(c) check "Do not allow ACL changes to be more restrictive than this."
(d) click "apply" on the bottom right.
(e) click on "advanced options" on the upper right.
(f) set share owner to "nobody", group to "nogroup"
(g) set all three rights to "read/write"
(i) check " Set ownership and permission for existing files..."
(j) check "Grant rename and delete privileges to non-owner of files."
(k) click "apply" on the bottom right. The "set ownership and permission" checkbox will clear, that is normal.
After a bit, you will get a popup saying that the set ownership is complete. Then switch to the next.
Hi Stephen,
I followed these steps and I can rename and move things on the ReadyNAS now from the Win7 PC and the 2nd WinXP PC. Your instructions were great!!! You have worked your magic and I thank you. It's good to know that I'm already in Security Mode. :)
You said "I don't recommend doing a factory reset (at least not yet)." Unless you can think of a reason to do that now, I think I am happy. :D
Thanks to you, Sir!
CBCC
