CBCC
Apr 04, 2014Aspirant
Permissions over Network
Hello, I am having trouble with my ReadyNAS Duo V2. I can do anything I want to from the WinXP computer that originally put the files on it, but not with other computers on my network. The ReadyN...
Jan 21, 2015Guru - Experienced User
It doesn't matter what bay the WD is in, it should boot either way. Your procedure should work - I suggest pulling drive 1 with the NAS powered down, being very careful not to write to the data volume when you test. Then power down again, and re-install drive 1.
If there's any chance that the data was written during the test you will need to hot-insert drive 1, which will rebuild the array.
I don't expect Netgear to make a lot of changes to the HCL, but user reports that on how well various drives work are helpful to the community of posters.
