CBCC
Apr 04, 2014Aspirant
Permissions over Network
Hello, I am having trouble with my ReadyNAS Duo V2. I can do anything I want to from the WinXP computer that originally put the files on it, but not with other computers on my network. The ReadyN...
Jan 24, 2015Guru - Experienced User
There should be no need to defrag (and you can't do it from windows).
I don't know if the recovery software would find anything, but if it is free there is no harm in trying. If the music is commercially sold, then it's probably cheaper to rebuy than to invest in paid recovery software. (If you purchased it from itunes you should be able to re-download it, not sure about other music store policies).
