NASguru
Oct 14, 2016Apprentice
Photos II - Mobile Chrome prompting for Credentials
I'm not sure if anyone else has noticed this but I recently shared a photo album with friends/familes like I have done many times in the past. I typically check it via my mobile phone to make sure th...
- Oct 18, 2016
Hello NASguru,
So it appears to be a browser's Adobe flash version compatibility. I am not sure if there will be an update on ReadyNAS Photos II, I may need to check with developers.
Thanks for trying other web browser and figuring out what could cause it.
NASguru
Oct 17, 2016Apprentice
I appreciate it Jenn. So I did a little digging and it turns out that Google/Chrome and Apple/Safari intend to drop support for Adobe Flash. The Photos II app is based on Adobe flash which what I suspect may be the issue with the mobile Chrome version. That said, Safari on my friends iPhone was still able to open the link just fine. So will the Photos II app be updated to support HTML5 as that's what Google and Apple are preferring moving forward for mobile computing. On a side note, I was able to upload 1300+ photos to one album. It took forever though and I should have broken it up into 2 albums.
Thanks!
Thanks!
- JennCOct 18, 2016NETGEAR Employee Retired
Hello NASguru,
- NASguruOct 18, 2016Apprentice
JennC wrote:Hello NASguru,
So it appears to be a browser's Adobo flash version compatibility. I am not sure if there will be an update on ReadyNAS Photos II, I may need to check with developers.
Correct, that would be great to know if the developers have any plans to refresh Photos II. Otherwise, what alternatives are there? I saw there are add-ons to the new NAS for SQL and using packages such as Piwigo or Koken. The only downfall there is you must setup the backend which doesn't appear too difficult. https://apps.readynas.com/pages/?page_id=9
- JennCOct 21, 2016NETGEAR Employee Retired
Hello NASguru,
Can you give me the version of the Chrome that gets the problem?
- NASguruOct 21, 2016Apprentice
I sure can. Version 53.0.2785.124. See screen shot below if that helps?
- NASguruOct 22, 2016Apprentice
FYI, I recieved feedback on another post about HTML 5 that Photos II is being discountinued.
