KShackleton
Dec 05, 2018Aspirant
Pinout for RND4 four-pin external plugpack
I have a 4-disc ReadyNAS without its external power supply. EBay lists only sources for these power supplies from the USA, with extortionate freight charges - even entries that advertise "free international freight"!
There are lots of articles on the Web about intermal multi-pin supplies, but that's not this model. This one has a 4-pin external connector, a bit like a 2-way-radio microphone connector but a bit smaller.
Can someone please advise the connector type, pinout and the power specification of these supplies? Maybe even a part of this information.
Thanks,
Kevin.
If the model number is correct in your post, this one should be compatible: https://www.amazon.com/Netgear-ReadyNAS-314-RN31421D-100NAS-RN31441E-100NAS/dp/B013SA5OCM
- KShackletonAspirant
That is correct. However, Amazon do not ship to Australia. Hence the actual question - of the plug/pinout, so I can sort out a power supply myself without having to deal with international issues.
Thanks,
Kevin.
I didn't realize you were in Australia.
It should be a 90W (12 vdc, 7.5 amp) adapter.
I don't know the complete specs, but the RN314 Netgear adapter (which is compatible) should have CAM090121 on the label and a part code 332-10581-01. So you can google on those. Googling on "DPS-90FB A" might also help.
Netgear resellers in Australia might possibly carry the part. https://www.netgear.com.au/home/shop/#tab-onlinestores
